Brake/Park Light....
Old Jun 1, 2006 | 10:06 AM
Chris LS's Avatar
just blaze...
Default Brake/Park Light....
What would cause my brake light to stay on? Funny thing is, I walked out to my car last night and thought I left my lights on but they were off and the brake light was on. I checked the fuses and took out the "park light" fuse from inside the engine bay. If I put it back in, the light stays on....whats goin on w/it, I never had an electrical problem like this.
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old Jun 1, 2006 | 10:41 AM
mitsu420aT's Avatar
check the ground wire going to your e brake under the center console. actually you should be able to see it frome the cup/cig holder in the middle. just pull it out. its easy to spot.
Old Jun 1, 2006 | 12:09 PM
Stephan's Avatar
It might be the little plastic piece that actually attaches to your brake pedal up under the dash that activates your brake light sensor is.. I had mine brake on me on my CRX and all I did was put a nut threw the hole and tightened a bolt down on it and never had to mess with it again.
DSM Part Out
Old Jun 1, 2006 | 01:22 PM
AnthrAxNSB's Avatar
first
...brake fluid low.
Old Jun 1, 2006 | 01:47 PM
JR.'s Avatar
JR.
Originally Posted by AnthrAxNSB
...brake fluid low.
98 talon awd automagic
Old Jun 2, 2006 | 02:58 AM
DSMboost97's Avatar
How long will it last?
Wasnt there a post like this a few weeks ago? Id check the switch on your brake pedal, could be stuck or something.
Old Jun 2, 2006 | 07:34 PM
AnthrAxNSB's Avatar
first
Originally Posted by qbanjr9
It's not a joke. Empty your resevoir and watch what happens.
