Update on the talon
Old May 3, 2006 | 05:52 AM
elitist's Avatar
TR Balla Donor Supreme
Default Update on the talon
well the talon started running like shit all of a sudden after doing some work on it at Mike's house (flyinbyu2.2) it had idle surge really bad. Before it had ahd spuratic idle surge and nothing i couldn't live with but it was bucking and would not move until it was in possitive boost.. not to mention I was getting about 10 miles to the gallon lol. So after replacing this and that at Mike's house we finally figured it was because I have (what I thought was) a 91 awd computer and I have a 90. Anyways he remembered that I guess you have to redo 2 of the wires on the wiring harness for it to work correctly. Anyways so we take out the computer and instead of it being a regular 91 awd computer like i had thought we find out that it is a 94 Eprom! So I'm a little excited about that but more excited about possibly fixing my car. Sowe repinned the wiring harness and now the car is running like a bat outa hell. Previously the car wouldn't go past 14lbs. of boost, was stutering everywhere etc etc etc now everything on it is pretty much perfect.
Old May 3, 2006 | 06:18 AM
Ender.'s Avatar
Eis Aner Oudeis Aner
Glad to hear it!!
I was excited when I found out my 90 ecu was an EPROM. At least I am pretty sure. lol
Old May 3, 2006 | 07:49 AM
awdornowd's Avatar
Here is what I could find on what cars had eprom.
1990
* Inagural model year of the DSM
* Pop-up headlights
* Some high-end models had wheel covers
* All ECUs had EPROMS
* Front brakes change during the model year
* 1.8L models have the 4G37 engine, all others have the 4g63 engine
1991
* ECU changes mean that 1991+ ECUs don't operate the 1990 tachometer correctly
* Most ECUs had EPROMS
* First model year with ABS available. ABS not available with limited-slip differential (LSD)
* All high-end models had alloy or mesh wheels
* First year of the Galant VR-4
1992
* Non-popup headlights introduced on all models
* The first AWD Lasers were introduced
* Few (or no) ECUs have EPROMS
* ABS now available with LSD
* The engine changes from the 6-bolt version to the 7-bolt version in April
* Second and final year of the Galant VR-4
1993
* Big Brake Kit, 2-piston front calipers become standard on turbo models
* 7-bolt engines are now standard
* No ECUs have EPROMS
* Diamond-Star Motors ceases to exist
1994
* All cars built to California emissions standards
* The last year of the 1G car and the 1.8L NT models
* The last year of the Plymouth Laser
1995
* The inagural year of the 2G DSM
* Significant changes to the engine, body, and electronics
* New transmissions
* All ECUs have EPROMS
* Non-turbo models are based on the Chrysler 420A engine instead of the Mitsubishi 4G63 engine.
* OBD-II becomes standard on DSMs, along with two oxygen sensors
* Mitsubishi begins using some substandard crankshafts, leading to crank walk
1996
* The first year of the convertible Spyder
* The Mitsubishi 4G64 engine is offered in the Spyder models only
* ECUs stop having EPROMS
1997
* Additional body changes from the 1995/1996 models
* Minor changes to the ECU code
1998
* After many years, Mitsubishi issues a recall on the AWD DSM transfer case
* The last year of the Eagle Talon
1999
* The last year of the 2G car, and of the 4G63/AWD DSM platform
There we go guys, i hope this helps, if you have any problems or questins with this, let me know.
Old May 3, 2006 | 12:28 PM
Kristin's Avatar
call me Gangsta boo
Woot!!!
Please check out this link...
http://www.BeautysEquineRescue.org
Old May 3, 2006 | 12:30 PM
Figs's Avatar
Thats awesome Mike, glad everything is running right. Seems like you've been having some good luck with that car.
Old May 3, 2006 | 02:21 PM
flybyuin2.2's Avatar
The car was charging at over 16 volts when Mike stopped by my house, the battery was cooking, all i did was change out the alternator as i have plenty of spare parts and it did not want to run right with a good one! Typical DSM Glad that it is running all better now
Old May 3, 2006 | 04:24 PM
elitist's Avatar
YEs thanks Mike!
BTW not all 90's had eproms... my origional 90 ecm was not eprom
Old May 3, 2006 | 04:32 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Originally Posted by MitsubishiMike
YEs thanks Mike!
Yeah, my 90 isnt eprom either.
SUCH IS THE RULE OF HONOUR.
Old May 3, 2006 | 05:34 PM
Psi TERROR's Avatar
Yup My 90 ECU was a non e-prom.
Old May 4, 2006 | 07:03 AM
Ender.'s Avatar
Kind of off topic, but I am like 98% sure my ecu is eprom. I dont feel like searching but does someone have a pic of the eprom board?
Thanks!
