Headlight cut out question
Yea I thought maybe a hole saw to start with so I could get the skill saw in then the skill saw to finish it off and maybe some high grit wet sand paper to smooth the edges after I am done
Like so?
The guy just cut a hole through the lense with a hole saw and cleaned it up with a Dremel; Epoxied a pvc tube in.
And I found this 1g
ahhh so you don't need a hole saw after all... I would use a dremel or something with a lot of precision. Ill probably end up doing something like the first pic but with black spraypainted or clear pvc so its not as noticeable.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
-Dario
If its on your friends car, i dont see why its so hard to figure out. You dont have to tape anything off, its not going to change the way the plastic melts and forms. All you have to do is sand the edges and then heat up some metal of your choice and use it to smooth the edges to look like clear plastic and not something that was cut and sanded. A cut-off wheel, dremel, sawzall or anything of your choice to cut it doesnt really matter, your trying to over complicate something that isnt complicated. There is also a thread in dsmtooners about this as well.
SUCH IS THE RULE OF HONOUR.
Originally Posted by SLOWBOOST
If its on your friends car, i dont see why its so hard to figure out. A cut-off wheel, dremel, sawzall or anything of your choice to cut it doesnt really matter, your trying to over complicate something that isnt complicated.
Well my friend that has it lives in Cali so it's kinda hard to base it off of his
Also yes I am stock SMIC
and I also tried it and it's alot harder than it sounds... i ended up cracking it and having to make it a little larger than I wanted to elliminate the crack.. overall it doesn't look horrible but soon I am gonna find another turn signal housing and redo it.. I will post pictures up a little later
