another stupid question
on the 420a block ,
where the oil filter screws on to ( the housing that bolts to the block)
what is that called and where can i get the gasket
There or could be your front main seal. Usually it would be your front main seal if its leaking around that area. Could also be part of your oil pan gasket. Degrease/clean around there and just take a small drive and then look under. You might be able to see it better that way.
