afc drawing power?
Old Mar 17, 2006 | 09:28 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
Default afc drawing power?
the car is getting crappy voltage when the afc is connected, but then when i disconnect it, the car can run with the battery disconnected. whats wrong? is it something with the mas?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 17, 2006 | 10:19 AM
Dario99gst's Avatar
Tu Papi Chulo
what??? your car should always run with the battery disconnected. unless your afc is making your car idle extremely low and the alternator isnt charging at that low of rpm. Sounds like a weird problem.
You know who to call..... GHOSTBUSTERS!!!
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Mar 17, 2006 | 02:04 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
actually i wanted some real help. lol. im gonna try and figure it out, i hate having to figure stuff out by myself no body knows anything in my area
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 17, 2006 | 02:14 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
ok, its something with the MAS! i disconnect the MAS and the car can run with the terminal disconnected. any ideas?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 17, 2006 | 02:53 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
ok i dont think its anything to do with the mas or afc. i think its just cause it idles higher when i disconnect those. ok so dont worry about the afc or MAS. what else would it be...its NOT the alternator. its been tested and puts out the right amount. not the wiring, i hooked up a volt meter and it was getting power all thru the wires
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 17, 2006 | 06:01 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
screw the autozone alternators, i dont think the guy ever put the thing under the right load. im just gonna get one i know is good and see if that works
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 17, 2006 | 06:20 PM
Figs's Avatar
Discount Auto or eh Advance Auto Parts is your friend lol. I got my alternator from them when I had my 1g. So I'm guessing you narrow it down to being the alternator?
Old Mar 17, 2006 | 08:36 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
I find your first post confusing. Let's try to clear it up.
The voltage coming from the alternator is low when the AFC is hooked up. What voltage does it put out?
The voltage goes back to normal, around 14 volts, when the AFC is disconnected.
Ok, what are the settings on your AFC? The only connections I can see are wiring problems with the AFC shorting something or a similar problem, or the correction on the AFC making the car die out and idle too low.
What is it idling at when the voltage is too low? Have you set your idle properly recently?
Old Mar 17, 2006 | 08:39 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
i actually got it from advance...but they test it and are like yea its fine blah blah, but my friend said that they said that for his but they sucked, like when its cold it gets good volts like 13 but then after a little it goes down to like 11.5, then it spikes up for a couple seconds. i checked the wiring to the battery, and i dont know what else it could be
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 17, 2006 | 08:41 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
well, i dont think it has anything to do with the afc, i think it was only because it raised the idle when i disconnected it, and it idles around 1k normally.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
