map sensor
Old Mar 11, 2006 | 05:54 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
Default map sensor
ok, i have the map sensor that comes with the meth kit from www.alkycontrol.com but i dont know which spot to connect the meth kit to. a,b, or c? what are the other two for? do i need a power and ground for the map?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 12, 2006 | 06:47 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
anyone?? is there a power and ground i have to connect, or just the green wire from the alky controller.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 12, 2006 | 01:34 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
I'd give Julio a call in the morning, he should be able to answer that lickety split.
Old Mar 12, 2006 | 04:39 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
ok, well i found where the wires went, but whenever i connect them, the pump turns on
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 12, 2006 | 05:41 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
think the map is bad?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Mar 12, 2006 | 06:11 PM
DeadSexY's Avatar
diballacully slow
here's some change 4 ya 2 cents to be exact.... you should leave that kit alone untill you KNOW what your doing.
Old Mar 12, 2006 | 06:24 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
well the map i got didnt come with any wiring diagram. that wouldve helped, and i found out the the kit i bought was a 5 bar kit with a 3 bar map so thats my problem. i need to get the controller calibrated.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
