Montero Sport problem
Old Mar 10, 2006 | 12:21 PM
o1yellowGT's Avatar
2wheels > 4 wheels
Default Montero Sport problem
we have a 2001 Montero sport 3.0 v6 xls,4wd.Heres the problem.it starts fine but when you drive and come to a stop it dies.Almost seems like if Im not pushing the gas pedal it doesnt get fuel. I m guessing fuel pump ?
Where can I get this diagnosed without going to the dealer ?
Any help would be appreciated...
Old Mar 10, 2006 | 02:55 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Just start checking the basics, if the fuel filter is relatively easy to access, try replacing it. Maybe change out the plugs, depending on the miles maybe the spark plug wires and distributor cap (if it has one). Basic tune-up stuff first.
Old Mar 10, 2006 | 03:18 PM
o1yellowGT's Avatar
2wheels > 4 wheels
Changed the filter and added system cleaner.Plugs arent accesible The whole top plenum has to come off to change the plugs...Heres the weird part...When I put the ac on it runs fine at a good rpm..Could this be a belt problem ?
Old Mar 10, 2006 | 03:35 PM
Figs's Avatar
Does the ac run on just that belt or do other acc. also run on that belt? Is the "Check Engine" light on? I heard that Advance Auto has a diag. machine they can plug into the diag. port to see why the check engine light is on. Funny thing my check engine light came on 2 days ago and I was at Advance Auto today and forgot to ask lol. Could it be a short somewhere? When was the last tune up performed on the vehicle? Could it be the alternator? So many different things. I would have Discount Auto Parts bring out their battery/charging system test machine out. I believe it tells you if its your battery/alternator/starter. It could be so many things.
Old Mar 10, 2006 | 04:18 PM
o1yellowGT's Avatar
2wheels > 4 wheels
new battery,I think it may be the tps .No check engine lights,multiple belts.I dont think it is the alt,It seems more like a sensor or fuel delivery problem..
Old Mar 10, 2006 | 09:12 PM
Jordan Y.'s Avatar
It runs fine if you turn the AC on? Turning the AC on raises the idle. Maybe the idle is set too low and it's letting it die out when the AC is off, or maybe the idle speed control motor is going bad.
Old Mar 11, 2006 | 03:55 AM
o1yellowGT's Avatar
2wheels > 4 wheels
I am going to have the Idle speed control checked as you are the 3rd person who suggested this..I have to go to the book store to see if I can find a repair manual for this truck..
Old Mar 11, 2006 | 08:35 PM
BoostLogik's Avatar
BoostAddict
I second the ISC Motor being shot, if it's part failure related.
As Jordan mentioned though, make sure your idle is set at spec settings. If it is, then maybe look into replacing the ISC Motor, since it's a somewhat expensive part.
Old Mar 12, 2006 | 05:23 PM
o1yellowGT's Avatar
2wheels > 4 wheels
IAC is $190.00 !! I cleaned the throttle body and it seems fine now !We'll see
Old Mar 13, 2006 | 07:11 PM
Jordan Y.'s Avatar
Sometimes the simple tune-up fixes can work wonders. Hope it works out for you.
