Eclipse running like shit
Old Mar 7, 2006 | 10:49 AM
jeffronismo's Avatar
Don't be a quitter...
Default Eclipse running like shit
My girlfriend has a 96 Eclipse RS. Lately It has been running like shit. At idle it will sputter off and on and sounds like it is going to die. Also, recently it seems to lack a lot of power... can't afford to lose any as it is. When u get on it, it takes a minute to pick up and move. The check engine light has been coming on and off and she took it somewhere and they told her the o2 sensor is dead. Do you tihnk that replacing the 02 sensor would stop all these problems or is it something else? I'm new to mitsubishis. Thanks, JEFF
Originally Posted by satanshatch
"If it's got tits or wheels you're always going to have problems with it" - My father
Old Mar 7, 2006 | 11:11 AM
Brandon's Avatar
Resident Dingo
Change the O2's and i think that would fix it because most of the time when it's dead the car will stall so maybe it's just on the way out. If that doesn't work check the idle/air control system, if it's plugged up and sticky it's going to slow the car down significantly and i do believe that would make the sputtering happen as well. Anyone feel free to correct me if im wrong, but thats my .02
--brandon
Old Mar 7, 2006 | 11:21 AM
thanks mr. p. Where is the idle / air system located?
Old Mar 7, 2006 | 01:17 PM
hunntyr's Avatar
Idle Air Controller (IAC) is located in the throttle body facing the firewall.
Old Mar 7, 2006 | 01:51 PM
Brandon's Avatar
Resident Dingo
Hector i can always count on you when im not hittin up the boards
Old Mar 7, 2006 | 04:53 PM
Figs's Avatar
Should probably be the O2's. My girlfriend had to have those replaced on her RS.
Old Mar 20, 2006 | 08:27 AM
I replaced the downstream 02 sensor and the engine light went off.The car still idled rough and when accelerating it would sputter or miss. I replaced the air filter and the plugs and now it runs fine. It ended up being a cracked plug so it wasnt firing right all the time. Thanks guys for the input
Old Mar 22, 2006 | 08:55 AM
Skyline Driver 5's Avatar
round and round it go
My mom needs to have her o2 sensors replaced too. She's been driving like that for a while and I dont think anything should get worse. Isn't there more than one o2 sensor?
TR "Old Skool EF" Member #150
