h/o alternator
OG MUDBONE 240sx
h/o alternator
if i put a high output alternator in my car, will it overpower the battery? i am gettin one, cause im puttin in a subwoofer with a 3600watt peak and 2500 rms.
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
What is the Amperage?
You do need to upgrade your wiring both the Alt. to Battery wire, and Your Grounds.
You really should have an Optima Battery whether it's Yellow or Red. And the Optima Battery SHOULD have no problems with higher Amperage Alts.
WTF 2500 rms if its a good brand sub/amp you must be dumping a few grand into this system
OG MUDBONE 240sx
like 400(used) and around 700 or something for a new one. the sub itself weighs 85lbs. then i need an amp and alternator.
Srqspeed.com
-Dane
