Interesting Problem...
[QUOTE=BROTHERS]
Makes sense. They've always sqeaked since Ive owned the car...
Ill shoot you guys a PM in a lil bit.
Originally Posted by Ender.
Are you saying when your axles were bad it did that in the rain?
Im going to start by just having all the accesory belts replaced, after I fix the oil leak. They sqeak and squeal to all hell.
RJ yes I need that valve cover. Ill call you this weekend or if you are going to be up this way feel free to stop by. Go put it in your car, Now.
[/QUOTE
who replaced your belts it looks like the belts are your problem they might not be getting tighten properly so when they get wet the start to slip which would cause the dash lights to come on and the power steering to get stiff also for the smoke it could of been just that you wet the exhaust with the puddle of water and was smoking.
[/QUOTEwho replaced your belts it looks like the belts are your problem they might not be getting tighten properly so when they get wet the start to slip which would cause the dash lights to come on and the power steering to get stiff also for the smoke it could of been just that you wet the exhaust with the puddle of water and was smoking.
