Blown shock?
Old Jan 25, 2006 | 06:29 AM
Shaun_GST's Avatar
<<<Tampa<<< >>>Bay>>>
Default Blown shock?
I've never had a blown shock but im assuming thats what this is. I have Tokico Blues, not even 2 years old. Hell, barely over 1 year old. When i hit a bump, i hear pshhhhh. Assuming air is coming out of the shock. Correct me if im wrong and why the hell is the shock blown at only 1 year?
Gripped XS | 18-55 IS | 50mm f/1.8 MK II | Sunpak 5000af
Old Jan 25, 2006 | 12:25 PM
Ender.'s Avatar
Eis Aner Oudeis Aner
I could be wrong, but the spring rate is too much for the shock to handle, not allowing for enough rebound or something along those lines... There is a better word I just cant think of it.
If you can lean on the car on the shock that you think is blown, youd be able to just push the car right down. Depending on how bad its blown.
Old Jan 26, 2006 | 03:59 AM
Shaun_GST's Avatar
Spring rate is too much? I have the Eibach Pro Kit. Hard to believe that is too much. And the car doesn't just push to the ground. its still stiff, but that could just be the springs.
Old Jan 26, 2006 | 04:39 AM
Ender.'s Avatar
Is the ride bouncy at all?
Old Jan 26, 2006 | 06:22 AM
Shaun_GST's Avatar
thats the thing, its riding fine as of now. its only the front pass side when i hit a dip in the road. i can better explain the sound. say you have an air compressor. hit the handle on the air compressor to release the air. TSSSS. You get the idea. I think its the shock because really what else could it be?
