need some gst advice
Old Jan 21, 2006 | 05:35 AM
str33tracer_18's Avatar
Originally Posted by Dario99gst
dude i run 26psi all day long stock head no cams and stock bottom end. with all supporting mods of course
are you being serious? if so exactly what supporting mods did you have.what turbo were you running.
Old Jan 24, 2006 | 05:56 PM
TampaTSi's Avatar
I've run 24 psi on pump gas and the stock 6 bolt bottom end, but I get about 4* of knock when above 22 psi. All supporting mods:
walbro fuel pump
660 injectors
VP FMIC
dsmlink
Hahn Super 16G
I've known a guy to run closer to 29 PSI on a 16G setup with the same supporting mods with C16.
I was running 20 PSI w/ the 14b on the 6 bolt with a walbro, 660s, dsmlink, and the stock SMIC, but I was heat soaking the SMIC. My intake temps were too high and I was getting > 5* of knock and pulling timing. I was a typical summer night in Florida though (hot and sticky).
1998 Eclipse GST
Old Jan 25, 2006 | 02:14 PM
slowsohc's Avatar
Eat a dick
Originally Posted by BROTHERS
just leave the stock side mount on there with the 16g my friend ran his car with a 16g and a stock side mount and ran 25 psi and it ran pretty good my advise work your your fuel first then worry about more boost and bigger intercooler.
This would work but if I was you I would not try that high of boost. I can only imagine how much tinig he was pulling and how much he was heat soaking that thing. The Bar and fin intercoolers do get good flow, but remember you have to have your supporting mods. And I can tell you that out of all the supporting mods I bought when I had my GST the worst one I bought was the AFC. My opiniion is tell your friend to keep the intercooler go ahead and get the 16g but dont put it on and start buying supporting mods and then get a DSMlink.... should be good to go after that. Do you have any pics of this intercooler or maybe some more specs of it?
-Mike
Old Jan 25, 2006 | 06:30 PM
F4A22's Avatar
Old School
I traded him that intercooler.Its 4rdrwhore's old one from his gvr4 and good for what your friend has until he upgrades.We used a similar core on a gst a long time ago with a 14b,afc,exhaust,wally 255,and clutch and the car went thru a set of nitto drags in 3 weeks and ran 13.7@107 on his first pass ever at a dragstrip.Tune it and max the 14b and then think about upgrading.
Old Jan 25, 2006 | 06:45 PM
Brandon's Avatar
Resident Dingo
I think Fernando is running a similar size core if not larger on his t25
It's 24x12x3. That FMIC was put on for a GT series turbo that was going on, then i sold the car. blah
--brandon
Old Jan 25, 2006 | 08:41 PM
Dario99gst's Avatar
Tu Papi Chulo
Originally Posted by str33tracer_18
are you being serious? if so exactly what supporting mods did you have. what turbo were you running.
I guess now is a good time to finally tell the world what i have. I've been trying to keep it under wraps here goes its not much but still a work in progress and I'm going to list it in more or less the order it was installed too.
Walbro 255 hf with a rewire.
780 injectors and a b&m fuel pressure regulator.
e01 boost controller.
E-manage.
chipped e-prom ecu.
XS power inter-cooler (not exactly sure on the specs but its huge.)
custom 2.5 inch inter-cooler piping.
type R blow-off valve.
GT-30R
still to come a 2g head match ported to a cyclone with some cams and valve springs. cryo treated tranny with LSD and cryo treated axles. oh and AEM.
I may have missed something so John please add to the list I am finally going to put it in my garage.
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Jan 25, 2006 | 10:25 PM
  #17 (permalink)
LS1Fever's Avatar
The FMIC is 30 x 12 x 4.... thats 4" thick with 3" in/outlets.
Centerforce clutch
Short shifter
Tein S with AGX 4 ways
Punishment 2.5" o2 housing to 3" Megan catless DP to 3" Greddy EVO catback
Ported 2G manifold
Custom 3" intake pipe
Custom quick release battery terminals Dario and the BROTHERS know
Theres more in the car, but just all electronics.
Old Jan 25, 2006 | 10:41 PM
  #18 (permalink)
2ndGenDsm's Avatar
Ughh...My fmic does me no justice for going any faster....it just looks nice ...lmao...
and now introducing my newest toy...
-Silver Slow-poke-
Old Jan 26, 2006 | 07:31 PM
  #19 (permalink)
Dario99gst's Avatar
Tu Papi Chulo
neither does mine
sorry I couldnt resist.
-Dario
Old Jan 26, 2006 | 10:50 PM
  #20 (permalink)
2ndGenDsm's Avatar
neither does mine
That was very....
-Silver Slow-poke-
