6 bolt swap
Old Dec 29, 2005 | 05:50 PM
25 to LIFE's Avatar
Default 6 bolt swap
gonna do the 6 bolt swap into a 95 GST. do you guys know where i can find some info on what is needed such as wiring, and maybe what should be expected in fab or bolting up? do i run the same ECU? thanks
Old Dec 29, 2005 | 05:52 PM
Dario99gst's Avatar
Tu Papi Chulo
you are doing it your self or you are going to pay someone
-Dario
DiSplaceMent Replacement
IF YOU NEED ANYTHING FROM CHASE PM ME!!
Old Dec 29, 2005 | 05:54 PM
25 to LIFE's Avatar
Default che
myself, its against my religion to let others work on my car
i am able to do what ever needs to be done on the GST. i just have never looked into doing a swap
Old Dec 29, 2005 | 06:33 PM
Dario99gst's Avatar
Tu Papi Chulo
easy there killer it was just a question.
I am very mechanically inclined and wouldnt do this swap on my own.
To do a six bolt swap you need a 1g cas the harness for the 1g cas, You need to fab your motor mount by the timing belt so it can fit around the water pump, of course you will need a complete bottom end with the flywheel. There is also the issue with what head you are going to use If you keep the 2g you might have the random misfire. But if you go with a 1g you'll have to get a 1st gen water pipe and housing too along with the intake manifold.
Im sure all this info is on the web somewhere just dont remember all the dsm sites off the top of my head.
HAVE FUN!!!
-Dario
Old Dec 29, 2005 | 06:42 PM
turboeclipse's Avatar
Adm1n1strat0r
honestly at least from me the swap wasnt hard, first time i ever worked a car too all u have to do (if swapping the entire motor) uis have someone cut out the 2g motor mount (plasma cutter worked for me) and rewire the cas to the 2g i did all om my own but had jerry do the wiring
(\___/)
(")__(")
This is Bunny.
Copy and paste bunny into your signature to help him gain world domination.
Old Dec 29, 2005 | 06:50 PM
25 to LIFE's Avatar
Default a
HAVE FUN!!!
sorry, i didnt mean to come off wrong to your question.
its a bad reaction to bad experiences on here. any way
yes i want the full swap, head and all.
Old Dec 29, 2005 | 08:52 PM
Adm1n1strat0r
if ur close and need help let me know
(\___/)
(")__(")
This is Bunny.
Old Dec 30, 2005 | 02:16 PM
BOX SENTRA's Avatar
OG MUDBONE 240sx
i dont think the 2g head bolt holes fit with the 1g block. could be wrong though.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Dec 30, 2005 | 03:49 PM
Road Rage's Avatar
Shake n' Bake
just trade me my 6 bolt 95 for your 7 bolt 95......
Old Dec 30, 2005 | 07:07 PM
TampaTSi's Avatar
2g heads will have to be drilled out to work w/ a 6 bolt
1998 Eclipse GST
