idle problem
Old Nov 29, 2005 | 12:21 PM
over da bridge's Avatar
Arrow idle problem
my galant idles high than will go right back down an then up again sounds like its purrin anyone kno whats wrong lmk thanks tobey
Old Nov 29, 2005 | 12:40 PM
Ender.'s Avatar
Eis Aner Oudeis Aner
Welcome to idle surge.
Is this a vr4? If so check the BISS Screw located on the throttle body, it might just need to be adjusted. Im not sure if n/t have them as well.
Other problems might be but are not limited to, the ISC as well as the ECU having leaky caps.
Old Nov 29, 2005 | 12:46 PM
no its a gs
Old Nov 29, 2005 | 12:48 PM
Ender.'s Avatar
Originally Posted by over da bridge
no its a gs
Well look for what I described and see if that helps any...
Old Nov 29, 2005 | 12:54 PM
ok will do thanks ill let you kno if it helps
Old Nov 30, 2005 | 08:55 AM
supertalon's Avatar
Beans
anyone know about that problem on a 93 talon?? i have the some problem. any solutions?? sorry to ask this on YOUR thread ODB : )
just your average day grocery getter....
Old Nov 30, 2005 | 10:02 AM
lol its all good if you have the same problem no need to say sorry
Old Nov 30, 2005 | 12:02 PM
Ender.'s Avatar
http://www.plymouthlaser.com/biss.htm
Theres some more info about the BISS. Also check for vacuum leaks. There are so many things that can cause Idle Surge, if you do a search on any DSM forum there will be many diagnosis's for it. Good luck in tracking down the problem.
Old Dec 6, 2005 | 03:53 PM
russellbeermann's Avatar
F*ck da rent, get the Lex
vacuum leak, check the gasket for your intake mani. this was my problem in the past
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Old Dec 7, 2005 | 07:37 AM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Any leak after the MAF will cause that problem. Check all your vacuum hoses, the intake pipe, proper function of the FIAV, intake mani gasket, injector seals. Then go after the electrical- properly set your idle, test the ISC.
