No pulse in the injectors
Old Oct 26, 2005 | 05:27 PM
eagletalonturbo90's Avatar
Question No pulse in the injectors
I blew the motor in my 1G AWD turbo Eagle Talon. We changd the motor. I am now getting fire in the plug wires, but there is no pulse in the injectors. we checked all the ground, Crank shaft sensor, and the ECU.
We put my ECU in another car the same as mine (same ECU codes too). at first the car (other car, not mine) started up and worked fine, so we just left my computer in it. We put the ECU out of the other car in my car. A couple days later, the other car started really hard and eventually would not start at all (no pulse in the injectors either). We took the ECU back out of my car and put the original one back in the other car. The other car started and worked perfect.
The original ECU out of the other car would not pulse the injectors in my car.
Any suggestions, email me at joeyb85@gmail.com
Thanks
Old Oct 26, 2005 | 07:27 PM
Redlinegvr4's Avatar
Boom Goes The Dynomite
cam angle sensor.
United States Air Force!
Old Oct 26, 2005 | 07:40 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Starting simple, check the MPI fuse right off the battery.
