Rotor Dimensions spec request
Anyone have a spare rotor laying around that they can get measurements off of for me? I need full measurements. I'll get a picture of a rotor with all the dimensions I need a little later to help out with exactly what I need. This is for a 91 turbo t/e/l. Thanks
You're going to let me know the details on this, right?
I can pull a rotor off this weekend if you need me too. It's a small rotor.
So we're talking about the bigger of the single-piston AWD rotors, the smaller one being the early 90 AWD rotors? I'm not sure how FWD works, whether they had the same brakes until the 93 AWD's got the dual pistons, or what.
But of course Joe. I already know what outside Dia. I will use for the rotor setup that will still be able to brake "hard" and be as light as possible. Probably going to a couple sets. One with a big rotor(12.19) one with a medium rotor(11.75) and then with something your vehicle weight range if possible a small rotor(10.50). It's going to be a setup with a mounting hat and seperate rotor disk. So some of the dimensions I will need is stuff like center hole dia., face thickness, clearance I.D. and offset. I'll email you a detail sheet with blank dimensions so you can fill it out to make it easier and to double check so I have everything I need. PM me your email.
I will document everything I find with photo's, full detials and any autocad drawings I might have for brackets and all that info will be shared with a few. And yes you are one of them.
Jordan - I will be custom making brackets for the calipers that will be used. I have not decided which set of calipers to go with but they will be 4piston and as light as possible. The rotor Dia. doesn't really matter for what I need as it will be up to the person on what dia. they want to use and then the right bracket for that setup. I'll go look for a detail sheet for what I need and post it up in a second.
Picture- (I need all dimensions on the ride side of the photo and also the over all dimension from the outside of the "face" to the outside of the rotor surface(by outside I mean the part closest to the car).
