gettin rid of abs
Old Oct 9, 2005 | 01:08 PM
25 to LIFE's Avatar
Default gettin rid of abs
any suggestions on taking out the abs on my 92 awd talon?
i have some ideas, just wanted to see if s/o has done it b/f or has other ideas.
thanks
Old Oct 9, 2005 | 06:49 PM
Nick's Avatar
Ridin dirty
Its was real easy with the motor out of the car.
AIM: Boost113
New best time @ Jennings 1:25.4
Old Oct 10, 2005 | 03:08 AM
Frankie Figs's Avatar
Too Much is ALMOST Enough
You have to get a non-abs proportioning valve and front brake lines from the valve to the wheel well. I think that might be all but I'm not sure.
Old Oct 10, 2005 | 06:55 AM
Skillionaire's Avatar
Nobody
From what i can rememeber that is correct. I did my 93 talon a while back and while it was a bitch, it was pretty straight forward, just time consuming. A few other essential tools will be a set of flare wrenches and this little tool that looks like a small set of hand held bolt cutters. The reason for the second one is because you will want to cut the old front lines out of the car if you are leaving the engine in. Go to a junk yard and find a non-abs 1G and get the proporting valve (on the firewall) and the front lines.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Oct 11, 2005 | 06:56 PM
DarksideZ's Avatar
TR Balla Donor Supreme
I'm sorry don't mean to sound like a dick but why do you want to take it off.
Old Oct 11, 2005 | 07:29 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Because early ABS is terrible and it saves some weight.
