Im going to set it on fire.
Still not fixed after replacing everything brake related. Next I will be doing the brake booster because someone on the galant boards has a 90 gsx with the same problem and hes replaced everything but that so Im going to give it a shot and see what happens!
Pray to whatever god it is you pray to for me, please. lol
You already tested the check valve in the line to the brake booster and it seemed fine, right? This problem is a real bitch, first the calipers, then the master, now the brake booster. Have you checked to see if there are any tests for these parts in the FSM? Might save you some cash if you can test it before replacing it.
did you check the rubber lines? i saw someone post soemthing about that.
They can cause all types ioof weird problems
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
eric.
Ive already tried blowing through the line and Its good. As for the rubber brake lines ,my only reason for not replacing those before the brake booster is because there is someone with a similar problem and hes already replaced everything that I have plus SS lines. The only thing that he hasnt tried replacing to fix it is the brake booster, thats why Im going to give it a shot. Ill find a link to his thread.
FSM= Factory Service Manual? I still dont have one, just a haynes. I should probably look into getting one...
I hope you can figure it out soon. I've seriously considered roasting mine, or pushing it in a lake. I'm not picky.
I took out some agression by spray painting DSM on one of my old skateboards and bashing it on a tree. It helped a little but Id still like it running.
srry your having problems man...No one wishes that on anyone, and I am not upset with you any more...No one deserves this many problems with a car...You are a nice guy too..The DSM gods just aren't on your side it seems...
Originally Posted by 91-Turbo-Laser
srry your having problems man...No one wishes that on anyone, and I am not upset with you any more...No one deserves this many problems with a car...You are a nice guy too..The DSM gods just aren't on your side it seems...The DSM gods have never liked me much but Ill be sure to show them when I have it fixed and get it to the track!
