need some help figuring where this wire goes....
Old Sep 5, 2005 | 05:31 PM
Undsptddsm's Avatar
Default need some help figuring where this wire goes....
whats up guys....well i replaced my clutch (with a WHOLE lot of trouble bolting it back on the block).....i got everything bolted up and everything is set except for one thing....i could be wrong but i dont remember removing a black and yellow wire from the starter....the situation is i have a pretty thick black and yellow wire that i can't remember were it goes, i'm not sure if it does go to the starter of it sits on the tranny as a ground?? like i said its a decently thick wire that is black and yellow and seems to be a ground since is comes of the negative terminal.....someone please help me this is all that is needed for me to finish my damn near 2 week project (which might i add was just changing the clutch )
thanks....
your only as fast..as the depths of your pockets..
Old Sep 5, 2005 | 06:23 PM
quadzilla's Avatar
thats your ground wire for the starter it gets bolted to one of the starter bolts
"Sit right here pimpin,let daddy holla at ya,Now daddy can do this ALL DAY, EVERYDAY,NO PROBLEM". MAKE A PIMP DECISION
Old Sep 5, 2005 | 08:06 PM
Undsptddsm's Avatar
i can also put it on the upper tranny mount can't i??
Old Sep 6, 2005 | 01:51 PM
quadzilla's Avatar
I guess you could,But the bolts for the tranny mount are a 17mm and a bit bigger than the 14mm starter bolts.I dont think the bolt will fit thru the hole in the connector on the wire.I would just unbolt one of the 14mm bolts on the starter and put it back where it was factory.
