Upgrade turbo question.
Old Aug 18, 2005 | 02:27 PM
JDMbyBlood's Avatar
Default Upgrade turbo question.
Whats up guys? Question for ya. My Cordia has a TC05, I think its a 14b turbo. (Small.) Im running 11lbs of boost from the stock 6lbs. 12 being the most before fuel shut off. Is it worth upgrading to say a stock eclipse turbo? Would there be more lag due to the larger turbo? Since Im only running 11 lbs of boost, Im I better off staying with the stock turbo?
Thanks...
Old Aug 18, 2005 | 02:33 PM
GsEclipse02's Avatar
a 14b is a stock eclipse turbo ...
Old Aug 18, 2005 | 02:52 PM
Ian MMF's Avatar
Omnipotence
Do you mean a tDo5?
Leave it alone man! You need to worry about fuel management before anything else if you are hitting fuel cut at 12 lbs.
Old Aug 18, 2005 | 03:17 PM
JDMbyBlood's Avatar
I think I'll just leave it alone. I wish there were an easy way to convert to MPFI. This 2 injector system kinda...well... sucks. I dont think the engine would last much longer If I were to bypass the fuel shut off and go crazy with the boost.
Old Aug 19, 2005 | 07:25 AM
Jordan Y.'s Avatar
15 seconds EXHILARATION
http://www.megasquirt.info/ms2/
Old Aug 19, 2005 | 12:23 PM
JDMbyBlood's Avatar
Thanks for the link, After looking and reading some of it, I think its a little over my head.
Old Aug 19, 2005 | 07:17 PM
emodsm's Avatar
red ass
the meag squirt is super nice but can be complicated.
Does the cordia have a maf on it? you can hack it if it dose that would put off the fuel cut out.
eric.
Build your car for YOU, not for the fame and glory. Fame and glory fade with time but YOU will be around as long as you live.
Old Aug 19, 2005 | 07:33 PM
JDMbyBlood's Avatar
I was told that I could cut a wire going to the boost sensor that controls the fuel shut off, but doing so will be would not be smart. (Engine may not handle it.) I wanted to cut it, so I can run 12 lbs of boost and if I get a couple more pounds due to a boost spike It would not go into fuel shut off. Not sure how much a 4g62 can handle. (I think thats what my engine is.) Its a 1.8L SOHC turbo engine.
Old Sep 6, 2005 | 12:07 PM
MightyMaxGS-T's Avatar
old school mitsubishi motors can take a decent amount of boost, but if you want to boost more there is a standalone made just for our generation mitsu motors with the TBI, and im working on an upgraded TB for it too...if you are have problems with fuel cut you should get a 1g eclipse MAF sensor...and that motor doesn't come with a 14b it's either a 9a, 11a, or 12a....all much smaller than the 14b
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Old Sep 6, 2005 | 12:34 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
I would sell the Mini and get an Electromotive Tec 3, some 1000cc injectors, a custom intake mani, and a GT35R. Then once the motor pops throw a built shortblock in there and some custom cams. Thats my $.02
