Need info
Old Aug 15, 2005 | 10:10 AM
Brothers's Avatar
TR Balla Donor Supreme
Default Need info
We are shopping for gauges for are car i have a couple of gauges that we like needed some ideas here are the list of the ones we have .
Defi-Link Bf 60mm peak hold
Apexi 60mm heak hold
Greddy 60mm peak hold w/s/b
Autometer Nexus peak hold
Megan racing
Info please
FullyBuiltInc.com
Brothers
A.K.A
Rob and Dave
Old Aug 15, 2005 | 10:15 AM
LS1Fever's Avatar
now you know what gauges i want. why dont yall just buy me the DEFI gauges and ill give you my Greddy peak/holds? hehehehe
Old Aug 15, 2005 | 10:27 AM
Ian MMF's Avatar
Omnipotence
What are the gauges used for?
Old Aug 15, 2005 | 10:33 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
no double, you went straight for the triple.
SUCH IS THE RULE OF HONOUR.
Old Aug 15, 2005 | 10:43 AM
Brothers's Avatar
just need some ideas we are thinking about the defi bf but still undecided
FullyBuiltInc.com
Brothers
A.K.A
Rob and Dave
Old Aug 15, 2005 | 10:52 AM
Ian MMF's Avatar
Omnipotence
All depends on what the use of the gauges are. I think peak/hold would be a little overkill for something like an oil pressure gauge. Also depends on what management system you are using and what you will be logging.
For something like boost, I personally like the greddy 60mm peak/hold w/s/b gauge but it is really hard to find in the 3bar version and well, I would ASSUME you are giong to be running more then 2bar so it would be kind of pointless. Also I don't think defi makes a 3bar gauge either. Find out what and what you need out of them and then find what fits that purpose.
Old Aug 15, 2005 | 10:57 AM
Brothers's Avatar
TRUE YEA I AM GOING TO RUN LIKE 38 PSI TO 40 PSI AND RUNNING AEM SO I AM GOING TO probably have to run 2 boost gauges 1 for vac and boost and then 1 for max boost still undecided
FullyBuiltInc.com
Brothers
A.K.A
Rob and Dave
Old Aug 15, 2005 | 11:00 AM
Ian MMF's Avatar
Omnipotence
Then find what companies sell gauges that read 40psi and then go from there on size and styles you like.
Since you have the aem ems and will be logging everything(I assume) a peak hold gauge is not really needed but wouldn't be bad when you are just doing pulls to check out little things like where your boost controller is set at and what not without having to bust out the lappy and go through logs, just for quick reference type bs.
Old Aug 15, 2005 | 11:12 AM
Brothers's Avatar
true i am going to run the aem wideband also so the list of gauges i am going to use is
boost 0-60
boost 30/30
oil pressure
water temp
egt
fuel pressure
aem wideband
FullyBuiltInc.com
Brothers
A.K.A
Rob and Dave
Old Aug 15, 2005 | 11:20 AM
BOOST JUNKIE's Avatar
slow
If money is no object, get the DEFI gauge set for sure (especially if you are planning to get a lot of gauges, it actually cancels out the initial cost).
