Need help please
Old Aug 8, 2005 | 02:15 PM
FastEclipseGSXT's Avatar
Use some Ray Rage! yea man hammer on a socket, where is Russ? tell his ass to help you out
Jeremy
www.myspace.com/biggrapes01
Old Aug 8, 2005 | 02:17 PM
russellbeermann's Avatar
F*ck da rent, get the Lex
Have you ever used those with a ratchet.
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Old Aug 8, 2005 | 02:21 PM
Oh trust me I've been Ray raging like a mofo. Have you done the hammer and socket thing before?
Russ
03 Infiniti G35
01 Lexus IS 300
Old Aug 8, 2005 | 04:26 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Originally Posted by Road Rage
i wouldnt use an impact tends to use to much force and the socket just spins, works best if you do it by hand....
If you are unable to use an impact gun without being able to control it, then I see where this might be a problem. And the socket will have to be on tight enough as to where it wont spin at all for it to actually come off.
Is it able to be plugged? Plug it up until you can get it off.
SUCH IS THE RULE OF HONOUR.
Old Aug 8, 2005 | 04:38 PM
Stephan's Avatar
were you talking to me? if so i had to buy them to get my lug nuts off because they were rounded off....
DSM Part Out
Old Aug 8, 2005 | 05:16 PM
Yes
Russ
03 Infiniti G35
01 Lexus IS 300
Old Aug 8, 2005 | 05:24 PM
  #17 (permalink)
Well I just spent over $300 in tools at Sears this bitch is coming off tonight I got a huge air compressor tank,1/2 impact,wheel lock remover kit,extension and adapter kit for impact, punch and chiesel kit,gator grip. Hope I didn't forget any accessories cause Sears is closed. But I found my breaker bar so im thinking that with the extension and one of my double sided sockets from my wheel lock remover kit I should get it done hopefully.
Russ
03 Infiniti G35
01 Lexus IS 300
Old Aug 8, 2005 | 05:29 PM
  #18 (permalink)
HondaEatingTSi's Avatar
4G63 PWR
The correct size of the lug nuts and wheel lock is a 21mm. And I just so happen to have an entire master set because I'm a Lexus technician. The only problem is I am in clearwater.
Honda/Acura certified Technician
Lexus/Toyota certified Technician
ASE certified
1992 Eagle Talon TSi AWD sold
2003 Maxima SE
Old Aug 8, 2005 | 05:32 PM
  #19 (permalink)
How late are you going to be up?
Russ
03 Infiniti G35
01 Lexus IS 300
Old Aug 8, 2005 | 05:33 PM
  #20 (permalink)
Clearwater is no problem.
Russ
03 Infiniti G35
01 Lexus IS 300
