Still having timing issues
Old Jul 29, 2005 | 01:37 PM
Road Rage's Avatar
Shake n' Bake
Default Still having timing issues
Ever since ive put this 6 bolt in the timing belt comes loose after it sits for a while(like an hour or more), but after you start its tight again, turn it off and its tight, even if its loose and you turn the crank by hand it tightens back up. Ive replaced the tensioner 3 times, belt twice, and both idler and tensioner pulleys. Ive also had the balance shafts removed, could that have something to do with it?
Old Jul 29, 2005 | 01:39 PM
PoppaSmurf's Avatar
Chowdah-head
have you preloaded and set the tensioner properly using the grenade pin? they are a major pain in the ass on those cars...no balance shaft shouldnt be an issue as long as you still have the pully on where the lower one goes, which obviously you do or the belt wouldnt fit at all....how much slack is it developing, just for reference?
Poppa J. Smurf
Old Jul 29, 2005 | 02:16 PM
Road Rage's Avatar
Shake n' Bake
yea tensioner and everything was set right, and it gets about an inch back and forth worth of play on the part of the belt on the back half, it really isnt bad until it gets loose enough to where it jumps teeth when you start it.....
Old Jul 29, 2005 | 02:19 PM
Undsptddsm's Avatar
hmm...if everything else is in right (like the tensioner..etc) maybe the belt being a little to big...intersteting situation....keep us updated...
your only as fast..as the depths of your pockets..
Old Jul 29, 2005 | 02:37 PM
Tom N's Avatar
Non DSM.....DSM guy
Did you follow this http://www.vfaq.com/mods/timingbelt-1G.html exactly.
Tom
Old Jul 29, 2005 | 05:26 PM
dsmtuner's Avatar
gotta love the boost
who did the balance shafts? if the balance shaft bearing isn't turned to block the oil passage oil will bleed out of the oiler hole, whether or not this will cause your problem, not sure. But if your residual oil pressure is allowed to bleed, then this could be part of the problem.
SVT F150
Old Jul 29, 2005 | 05:42 PM
Road Rage's Avatar
Shake n' Bake
i didnt do this part...
Remove rubber plug from inner timing belt cover and screw special tool no. MD998738 (contact Miller Tool for this tool - 800-801-5420, http://www.spxmiller.com/ - search for part # MD998767 or MLR-MD-99873 into the engine left support bracket until it makes contact with the tensioner arm (Figures 4 & 5).
would that cause it?
Old Jul 29, 2005 | 06:03 PM
dsmtuner's Avatar
rage, quick question, did you catch the part about a month ago where i beefed up the pin on the tensioner? it also prevents it from bleeding down. If you want to do that. It would solve all your problems.
SVT F150
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
It might, ive never done that and never had a problem with my belts loosening up. Would never hurt to try to do what is supposed to be done though.
SUCH IS THE RULE OF HONOUR.
Old Jul 29, 2005 | 06:07 PM
dsmtuner's Avatar
god i wish my covers were off so i could take pictures of it.
SVT F150
