Price Check + Question:
www.myspace.com/filjar
on
Stock EVO 8 ECU
or
Flashed EVO 8 ECU
Trying to keep warranty on the Evo.
Also, What other bolt-ons (easily removeable/don't leave a trace) mods are there that should definately be done? Doesn't neccessarily have to be bolt-ons. I think we're gonna do boost gauge + boost controller.
Thanks.
or
Flashed EVO 8 ECU
Thanks.
Guest
Posts: n/a
y0u c4|\| d0 4 K&|\| d|20p 1|\| p4|\|3l f1l73|2 (c0ugh 1 h4v3 0|\|3 F5) 7h475 345y 3|\|0ugh 70 |23v3|27 70 570ck (Bu7 1 d0ub7 17'd m4773|2). Full 7u|2b0 b4ck 3><h4u57 h45 |\|1c3 g41|\|5 4|\|d 7h3 d34l3|2 d035|\|7 533m 70 m1|\|d 7h3m 50 much. 1f y0u fl45h 7h3 3cu y0u d0|\|'7 |\|33d 4 b0057 c0|\|7|20ll3|2, 4|\|d 7h3 d34l3|2 15|\|'7 |234lly g00d 4b0u7 f1|\|d1|\|g 7h47 0u7. 17 c4|\| b3 fl45h3d b4ck 70 570ck 1f |\|33d b3.
on
Just costs money for the flash. Already have injen full intake with uicp. So we figured we'd go with the turbo back exhaust and ecu reflash and call it a day. We can't lose the warranty. No need on boost controller? Why not?
So yeah then we just need the exhaust. Any suggestions John?
Boost controller voids warranty.
Get a good clutch cause the stock one will take a shit on you soon probably, safc, walboro 255(not needed at this point but if you plan on going faster eventually just get it now) and a full 3" turbo back and if you don't run 12s on pump gas and stock boost you shouldn't be owning an evo.
Guest
Posts: n/a
[QU073=F1Lj4|24L1F3]Ju57 c0575 m0|\|3y f0|2 7h3 fl45h. 4l|234dy h4v3 1|\|j3|\| full 1|\|74k3 \^/17h u1cp. 50 \^/3 f1gu|23d \^/3'd g0 \^/17h 7h3 7u|2b0 b4ck 3><h4u57 4|\|d 3cu |23fl45h 4|\|d c4ll 17 4 d4y. \^/3 c4|\|'7 l053 7h3 \^/4|2|24|\|7y. |\|0 |\|33d 0|\| b0057 c0|\|7|20ll3|2? \^/hy |\|07?
50 y34h 7h3|\| \^/3 ju57 |\|33d 7h3 3><h4u57. 4|\|y 5ugg35710|\|5 J0h|\|?[/QU073]
|23fl45h \^/1ll |23m4p 7h3 b0057 50l3|\|01d, upp1|\|g b0057 4|\|d 3l1m1|\|471|\|g b0057 74p3|2. 0|\|3 l355 p4|27 70 buy.
7B3? Bu5chu|2 m4k35 4 |\|1c3 0|\|3, 1f y0u \^/4|\|7 70 g0 m0|23 budg37 7h3 M3g4|\| |24c1|\|g d035|\|7 f17 7h3 b357 bu7 17 \^/0|2k5. 1 h4v3 7h31|2 d0\^/|\|p1p3/7357 p1p3 0|\| my c4|2, \^/0|2k5 \^/3ll 3|\|0ugh.
on
Thanks a lot guys. You've been more than helpful. So is it worth putting boost gauge in splicing a wire if no boost controller? Ill take a look at those exhausts.
A boost gauge is always a good idea.
I forgot about that, did you ever get the refund for the EGT?
