Clutch or Tranny problems
Old Jul 13, 2005 | 02:19 PM
97TSI's Avatar
Jewbling
Default Clutch or Tranny problems
i was driving my car today in traffic put the car into first gear i move no problem...i go into second my car kinda jerks alittle i hear a pop and now i cant get into any gear with the car on. If the car is off i can get into 1-5 but not reverse. My pedal pressure seems to be acting up as well its very soft ...when i let off the clutch pedal the point where it grabs is almost at the floor which is not where it usually grabs
my slave and master clyinder were replaced not to long ago and the fluid is full
only drivetrain mod i have is an ACT 2100 w/ organic disc which was put in about 15-20k miles ago
Old Jul 14, 2005 | 09:39 AM
Chris LS's Avatar
just blaze...
Have you adjusted the clutch pedal? I'm only saying this because I had a similar problem after swapping my motor. No sudden noise like a pop but I had to adjust that and the gears went in smoothly rather than forcing it when it woudln't go in....hope that helps.
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old Jul 14, 2005 | 10:11 AM
97TSI's Avatar
Jewbling
i didnt try to adjust the pedal i didnt have any tools on hand..the car has been towed and im waiting for the guy to call me back to see wtf happened
Old Jul 14, 2005 | 10:29 AM
FastEclipseGSXT's Avatar
sounds like a good place to start, the clutch pedal assembly including the master cylinder...
any updates?
Jeremy
www.myspace.com/biggrapes01
Old Jul 14, 2005 | 10:56 AM
97TSI's Avatar
Jewbling
any updates?
still waiting for the guy to call me back i ruled out the hydrualic system for now just because i had the slave and master replaced in the last 6 months or so and when i got off the road there were no signs of leaks and the fluid was filled completly...but i could be wrong
i hope its not the tranny ive gone through tranny problems in my maxima(auto) ate up 4 rebuilt trannys....and i had to sell the car
Old Jul 16, 2005 | 11:00 PM
VWFREFF's Avatar
World's Sexiest Fat Man
i had some problems like that with my car. first i woyld simply check the bracket tjat the shifter cushing go on under the hood are still on, the take out the slave cylinder, and replace the seal in it. it is a small o-ring. sometimes the added stress can cause that seal to blow. just my .02
originaly posted by 57trim aka Jazz
MOTHERBITCHFUCKSHITDAMN!!!!!!!!...........DIIIIG!! ! BITCH!!! DIIIIG!!!
TEH WHIPS!!!
I have a BIKE 06 Cannondale Prophet.
2002 EP3 Civic SI
Old Jul 17, 2005 | 05:32 AM
A97EclipseGS's Avatar
I had the same problem but it was the slave cylinder i shifted too hard and probly blew out the seals.Hopefully it aint too hard 2 fix
Old Jul 17, 2005 | 10:49 AM
97TSI's Avatar
Jewbling
it was my pressure plate that went out
