TT Problem
Old Jun 30, 2005 | 06:29 PM
NightRdnEclipse's Avatar
Ralfy
Default TT Problem
I just installed my turbo timer last night.Ok whenever I turn the key one time, and the engine is supposed to shutoff, it keeps running, I know this is normal but now I turn the key the rest of the way, and it completely shuts of the engine like if the timer wasnt even there. Anyone else run into this problem? Any suggestions? Thanx
Ralfy
-Ralfy
http://www.myspace.com/ralfy4
Old Jun 30, 2005 | 06:40 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
Ralfy
You wired it wrong.
SUCH IS THE RULE OF HONOUR.
Old Jun 30, 2005 | 06:46 PM
Ralfy
I bought the harness with it, so it was all just plug and play. I took out the ignition plug, plugged in the harness, plugged the ignition into the harness, and grounded it. My battery was unplugged for so long that I have to type the code in again, but that shouldnt matter.
-Ralfy
Old Jun 30, 2005 | 06:47 PM
Where did you ground it to?
Old Jun 30, 2005 | 06:56 PM
Ralfy
Its grounded under the steering wheel, metal on metal.
-Ralfy
Old Jun 30, 2005 | 07:18 PM
Ralfy
I guess I can try and ground it somewhere a bit more sturdy. But could the ground be the thing making my timer do this?
*Edit
The instructions never told me to plug a positive anywhere in the car where it can have constant power, can this be it?
-Ralfy
Old Jun 30, 2005 | 07:46 PM
Isnt there only like 3 wires that plug into the ignition, one ground, one ecu speed sensor, and an e-brake warning wire. Try that and post if it works.
