FS: SFP T4 turbo kit
SFP T4 manifold, Tial 40mm wg with dump tube, 3" VBAND downpipe, Turbonetics Tseries T61 .58 AR Ptrim turbo. This is a serious turbo kit, which you can run well into the 10s on a stock motor sans cams and a full weight car. Plenty of power.
This is not the typical T3/T4 setup...its FULL T4 to run the bad boy turbos.
$1500 for everything. All oil lines, hardware, gaskets,etc... infact it doesn't even need to be unbolted, can be installed with everything connected by just removing the manifold and gasket-less VBAND downpipe.
