evo8 engine in a eclipse rs ???
Ok, i havent checked to see if this has been already posted but anyways ... is it possible? i mean i havent dont much research but the transmission is on the same side and it looks like it would fit... but what about motor mounts and wireing wise ... and if so does anyone no who could do it?
even worse of an idea then putting a turbo eclipse motor into an RS.
If theres going to be EVO 8 engine swapping, there is a nice list of cars that would be wayyyy better then putting into a car that already came turbo.
Mike
95 Lancer GSR
93 300ZX 2+2
Mike
95 Lancer GSR
93 300ZX 2+2
evo engines spin the oppisite way of the 4g63 that we use, so that means the tranny has to come with, which means stop thinking about it, get a bowl of pasta and think about warm soft noodles sliding down your throat...
no he's not refering to that. means the engine internally spins opposite to the 4G63 from the 1Gs and 2Gs. which is why the tranny has to go with as well. otherwise youd have 5 gears of reverse, and 1 forward gear.
Mike
95 Lancer GSR
93 300ZX 2+2
Mike
95 Lancer GSR
93 300ZX 2+2
The evo8 engine turns the same direction as any 4g63. The tranny spins the opposite directions.
lol ls1fever u beat me to it....
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
Mitusubishi purposley did this so that it cannot be easily swapped and so that you can't just go buy a motor and put it into another car....but if you want to then go ahead and try cause if you pull it off, i will give you mad props, but on the money your going to spend you might as well just go buy an evo....just my 2 cents
