sfmu on a 420a ?
I have one on my 420A julian. As far as price goes, it all depends on where you get everything from. Best thing for you to do is search. You are the only one that knows how much money you are willing to spend. I bought mine for $200 not including the fuel lines. By the way..tick tock tick tock tick tock...track day is a couple of weeks away. Hope you will be ready to run with me by then.
its really not worth it for the cost, I used to use a RRFPR setup and hated every minute of it...you could get a MegaSquirt standalone for not much more....and it is a full standalone that decodes the 420a crank signal....or just use it to run fuel, whichever
on
were did you buy the fule rail and what not? and im going to be on stock internals i want to have like 230 hp.... the only things i have for tune are going to be a safc 2 and injectors
yeah 230 hp is easy to get sense i got 217 hp without any components such as...
egt gauge, apec II and etc...
I do recommend you getting those components because it will make it easier to tune and more Accurate.
I'm still have the hahn FMU but later in the future i'm going with the Vortech... or maybe something else... if you're only going to have 230 hp i think you should go with the hahn for the time being and you don't have to change the fuel rail only the fuel injectors...
yo when do you want to check out my ride??
-SilverTurbo has future plans in mind...
