4G63 AWD Fluid Specs?
Old Apr 4, 2005 | 06:22 AM
zlaja_gsr's Avatar
Default 4G63 AWD Fluid Specs?
What kind of oils are you guys using in your tranny, motor, t-case and differential? I got a 92 Tsi AWD with 129K. Any suggestions?
Old Apr 4, 2005 | 06:39 AM
89crxsir's Avatar
transfer case API GL-4 or higher SAE 75W-90 or 75W-85W
2.0L Eng
0.63 QTS.
same for the trans
diff API GL-5 or higher
2.0L Eng
0.74 QTS.
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Ep41382's Avatar
TR Balla Donor Supreme
use Mobil 1 synthetic, for the tranny use BG Syncro shift, t-case use Redline any 80-90 gear oil will work really, hope this helps
Eric
AIM: Ep41382
Old Apr 4, 2005 | 06:42 AM
zlaja_gsr's Avatar
what about the rear diff, what would u guys use there
Old Apr 4, 2005 | 06:43 AM
zlaja_gsr's Avatar
oh ok never mind i see it thanx guys
Old Apr 4, 2005 | 04:37 PM
TampaBlunt's Avatar
Boost-Happy Novice
ummm...i just use whatever 10-W30 motor oil the car wash has....happens to be penzoil at A+ (intersection of hills and countryway) 20 bucks for complete wash inside and out plus oil and filter...hit me up if you need the coupon...otherwise it´s 25.95 or something...i´m mechanically inept perhaps i shouldn´t own a dsm then....
Originally Posted by Dano Moparo
If we took a day off everytime some country kicked France's ass, we would never have to work.
Please Visit My Webpage! Click Here
Old Apr 4, 2005 | 08:59 PM
BoostLogik's Avatar
BoostAddict
How is the BG Syncroshift? I've heard positive and negative things about it. The positive of course being smoother shifting, the negative (according to what I read somewhere), is it supposedly "swells" the synchros.
I've heard really good things about GM Syncrhomesh for our car's trannies as well.
"Even through the darkest days, this fire burns, always"
Old Apr 4, 2005 | 10:32 PM
blackscorpiontsi's Avatar
For the tranny and t-case I use Pennzoil Synchromesh and for the motor Mobil 1 10w-30.
Old Apr 5, 2005 | 01:11 AM
Brandon's Avatar
Resident Dingo
motor oil = royal purple 10-w30
Old Apr 5, 2005 | 08:06 PM
zlaja_gsr's Avatar
have u guys had any expirience with red line oils
