I need a parts llist
Old Feb 21, 2005 | 05:29 AM
Redlinegvr4's Avatar
Boom Goes The Dynomite
Default I need a parts llist
I am gonna help goat with the 14b swap on his gsx he has the turbo. what else does he need. I have done the swap before but i cant remember what all is needed. Thanks
United States Air Force!
Old Feb 21, 2005 | 07:01 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
http://tampabay.dsm.org/phpBB/viewtopic.php?t=9480 this should help you out a bit.
SUCH IS THE RULE OF HONOUR.
Old Feb 21, 2005 | 07:46 AM
BoosTb4BroaDs's Avatar
i posted this before for him under his original thread, i was told this is what ya need. it sounds bout right to me
Parts needed:
14b
1g J-pipe
2g LICP
10" x 2" pipe (with beads welded at ends)
2g oil feed line (oil filter side)
1g oil feed line (turbo side)
1g or 2g drain pipe
1g or 2g water lines (bending needed)
Rubber fuel injection line
High-temp Copper/Silicone gasket maker
Total cost of install kit: $40
1. Cut the 2g LICP inbetween the two 90* bends
2. use 10" long pipe to raise LICP to the 1g J-pipe
3. cut 2g oil feed line near turbo
4. cut 1g oil feed line near the already cut 2g line
5. connect the two feed lines using fuel injection hose
6. install water lines, bend as needed
7. use gasket maker in place of mani->turbo, turbo->o2 housing, o2 housing->downpipe gaskets.
Old Feb 21, 2005 | 08:12 AM
thanks
Old Feb 21, 2005 | 08:18 AM
the second link within the link gets into the electrical shit.
Old Feb 21, 2005 | 12:20 PM
goat's Avatar
hey guys, where can i find a 1G j pipe?
and not the 70$ one from RRE.
Old Feb 21, 2005 | 12:36 PM
20psi17c's Avatar
hmm, all i did my swap with j pipe and both oil lines. thats it. i reused all my gaskets, but thats not good so go to mitsu and spend 20$ on gaskets. everything fit fine.
Old Feb 24, 2005 | 01:00 PM
goat's Avatar
i have all the piping taken care of now. I don't really wanna splice the fuel injeciton lines in, unless thats gonna save me a good amount of $$.
aside from that, does anyone have any of the needed parts for sale?
Old Feb 24, 2005 | 02:11 PM
what else is needed a 1g feed line? that should be it if ya got the 14b an all the piping
Old Feb 24, 2005 | 03:04 PM
goat's Avatar
alright, cool. Anyone have a 1g feed line for sale, or know where i can get one?
what about a banjo bolt. that was mentioned somewhere.
