Need Help! Questions About Pulling Motor
Old Jan 28, 2005 | 12:24 PM
russellbeermann's Avatar
F*ck da rent, get the Lex
Default Need Help! Questions About Pulling Motor
i have a 97 eclipse gst and we are pulling the motor today. we got the head and all the smaller components detached from the block, but we are wondering if there is any way we can pull the block without pulling the tranny. i have no idea how long the input shaft is, and i am assuming that if it isn't that long, all we would have to do is unbolt the block from the tranny, unbolt it from the motor mounts, and pull the block. has anyone pulled a motor from a fwd and could answer this question? thanks
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Old Jan 28, 2005 | 01:01 PM
Tom N's Avatar
Non DSM.....DSM guy
I am not sure why you would take the head off to pull the motor but to answer your question. Yes you can pull the whole motor with tranny and head for that matter. You just need to get under the car and drain the tranny and make sure the axels are out of it.
Tom
Old Jan 28, 2005 | 01:19 PM
i pulled the head because i bent the valves when my timing belt snapped. i didn't initially know that i had damaged the cylinder walls, but when i pulled the head, i saw that they were gashed
Russ
03 Infiniti G35
01 Lexus IS 300
Old Jan 28, 2005 | 01:20 PM
but could i just unbolt the block from the tranny, leave the axles in, and pull the block out? i really do not want to take the tranny out.
Russ
03 Infiniti G35
01 Lexus IS 300
Old Jan 28, 2005 | 01:24 PM
Tom N's Avatar
Non DSM.....DSM guy
I dont know. I would never even think of doing that nor do i know of anyone who has. I dought it though. Not to mention how hard it would be to get the motor and tranyy back to gether with the tranny in the car. I just dont see how it could be done. It would be way easier to pull them together. The reassemble everything and drop it back in whole.
Tom
Old Jan 28, 2005 | 01:34 PM
thanks triple g...saved me a lotta time
Russ
03 Infiniti G35
01 Lexus IS 300
Old Jan 28, 2005 | 01:44 PM
Brandon's Avatar
Resident Dingo
me and a friend of mine pulled the block without the tranny, and from experience i'll tell you... dont do it. It IS a bitch to get back 2gether.
Old Jan 28, 2005 | 02:27 PM
TampaTSi's Avatar
drop the tranny out the bottom, pull the block out the top. it's the easiest way.
1998 Eclipse GST
Old Jan 28, 2005 | 02:37 PM
Lay Maha's Avatar
Jaded Mitsu
drop both tranny and block from the bottom and hoist the front end up so it will clear. That's how I did it.
Old Jan 28, 2005 | 02:41 PM
dsmtuner's Avatar
gotta love the boost
it is much easier to pull it out as one peice just listen to every one else.
SVT F150
