can i turn "clock"a dsm t25 dsm turbo?
lol... you can Never clock a TD05-T25... for the sole reason that they dont exist.
you can clock a T25 OR a TD05... there is a pin where there exhaust housing meets the center section... chances are, that will break anyways when you try to separate the exhaust housing. for the cold side, that one is slightly harder with the C-clip and all.
you jus thave to worry about how you want to mount the Wastegate actuator... or eliminate it and run with an external. then you are free to clock any way you see fit.
nobody can just give the guy the benefit of the doubt and know hes talking about a stock turbo... either one, the answer is yes..
Mike
95 Lancer GSR
93 300ZX 2+2
Mike
95 Lancer GSR
93 300ZX 2+2
