free play adjustment
Old Jan 12, 2005 | 09:47 AM
dsmtuner's Avatar
gotta love the boost
Default free play adjustment
How do you adjust the free play on the clutch pedel on gen1?
SVT F150
Old Jan 12, 2005 | 10:27 AM
BOOST JUNKIE's Avatar
slow
Losen the lock nut and adjust the master cyl rod by turning it clockwise/counterclock wise. The adjustment is near the accel. pedal.
Old Jan 12, 2005 | 04:36 PM
dsmtuner's Avatar
yeah i know about that i have it adjusted all the way out and im still getting to much freeplay the pedel will go half way before it starts pushin the rod. Any suggestions?
SVT F150
Old Jan 12, 2005 | 05:34 PM
slow
I'm not sure if I am understanding you correctly. But, the clutch pedal assy. might be worn and need replacing. Its common on older 1Gs.
Old Jan 12, 2005 | 06:57 PM
dsmtuner's Avatar
oh ik is thats the prob im having is it hard to do?
SVT F150
Old Jan 13, 2005 | 12:36 PM
slow
Its kind of a PITA, but not a "difficult" task. The FSM has the procedure in it.
Old Jan 14, 2005 | 06:22 PM
dsmtuner's Avatar
ok i already got it out and a part thanks for your help.
SVT F150
Old Jan 16, 2005 | 03:28 PM
HotImportNightHonda's Avatar
Rubber Side Down...
You can also put a longer push rod on the slave cyl on the front of the tranny. They sell the rods at home depot. Just cut to fit. You might have to make a couple till you find the right one. Good Luck
It's just a 4cyl.
TR Double Stack crew #003
Old Jan 16, 2005 | 05:05 PM
dsmtuner's Avatar
Default clutch
Thanks for everyones input, the clutch works beautifully, now for the answer. If someone ever has this problem where the clutch doesnt engage, or engages partly begin looking for simplicity rather than transmission problems. It seems that it will happen to only the older 1st gens with the heavy spring return not the little one that goes on the pedal bar, The springs actual motion loosens the locknut that holds the pedal assembly onto the bar that runs across the top of both the clutch and brake pedal. To avoid the problem. I just put a newer clutch assembly out of a newer 1st gen under the dash to make sure it wont happen again, add this one to the books folks.
DSM TECH BULLETIN 3,427
SVT F150
