clutch problems
Ok im having problems with my clutch. My tranny took a crap like 3 weeks ago fine i pull the tranny out ok, i decided to put a new clutch in it i go to auto zone order the luk repset clutch kit for my 1993 eagle 2.0 non turbo. I put the tranny in adjust everything drives ok , the clutch pedel binds ok so i put a new clutch master cylinder in it ok now the problem comes in whaen the car dosent want to go into gear. No matter how much i bleed it my dad pushed the fork on the tranny farther than the slave cylinder pushes it and it goes into gear just fine this is got me stumped .If you guys got any ideas let me know. It also has a new slave cylinder in it.
SVT F150
SVT F150
no, the clutch i had in there was only in for about 6,000 miles, i left the flywheel alone and put the new luk clutch in, do you think that could have been a problem?
SVT F150
SVT F150
first off te does the car go into gear (without the clutch) when the car is off.....if so then it could be your slave cyl, pressurplate but if it was the fly wheel it would probably act like it woudl when the clutch goes....plus if your going to do one thing you should do them all while you have it out and apart.
Bizzare Customs
Land O' Lakes, FL
Bizzare Customs
Land O' Lakes, FL
yeah it goes into gear when its off the slave is new and the fly wheel has been cut already. If i have a heavier clutch do i need to extend the push rod and longer or do i need a stronger slave?
SVT F150
SVT F150
What clutch slave did you get?(Their are two different kinds) Also from your symptoms I would tend to think it's not your clutch but maybe your transmission. A transmission will always go into gear easier when the car is off because nothing is rotating.
what kind of slaves are there it isnt the clutch because when you put pressure on the transmission fork it goes into gear you just have to push it a little harder.
SVT F150
SVT F150
There are two different sized slave cylinders. One is longer then the other.
And what do you mean by "it isnt the clutch because when you put pressure on the transmission fork it goes into gear you just have to push it a little harder"
Complete sentence and grammar would help out ALOT in this situation. You're not 5 years old so stop typing like it.
