why remove abs??
Old Oct 27, 2004 | 12:11 PM
MadisFastDSM's Avatar
tractionless
Default why remove abs??
why do people remove the abs???? weight? brian
collision and refinising technician need bodywork/ paint call 727 776 7830
Old Oct 27, 2004 | 12:18 PM
Ian MMF's Avatar
Omnipotence
Weight and that fact that it seems quite a few 1g's have had problems with complete break failure do to problems with the ABS unit. Last thing I want to do is be making a high mph 1/4mile pass and have my breaks decide not to work at all thanks to the ABS unit deciding it doesnt want to work.
Tom N's Avatar
Non DSM.....DSM guy
Yes weight.
Tom
Old Oct 27, 2004 | 12:29 PM
tractionless
and ive also heard it shortens stopping distance on dry surfaces??
Old Oct 27, 2004 | 01:20 PM
Skillionaire's Avatar
Nobody
I removed mine because one of the hard lines connecting to the ABS unit cracked. IT would have been nearly impossible to replace that line by itself. A side bonus is that it does clear up a lot of room in the engine bay, and allows more room for IC piping and such. I did the job myself and it really wasnt all that difficult, just fairly time consuming. You can get everything you need from a junkyard. I also noticed improved braking feel with the ABS removed
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Oct 27, 2004 | 03:56 PM
Nick's Avatar
Ridin dirty
I did it for room
AIM: Boost113
New best time @ Jennings 1:25.4
Old Oct 27, 2004 | 04:24 PM
flubyux2's Avatar
Elitist Supra Asshole :)
it does make a cleaner apperance and less cluttered. hell, even this AWD i just got has the ABS fuse ripped out, so someone along the line thought ABS sucked. and Yes, ABS will degrade your braking performance on every surface, not just wet or dry..
the only benefit of ABS is to allow the driver to maintain control throughout a panic stop and avoid lock-up and loss of control... thats it. it doesnt make you stop shorter or better... its just safer, thats all.
but faulty equipment is far from safe. if you feel your ABS is compromising your braking performance, i would suggest removing it... it wont stop any worse than the NON-abs cars on the road.
Old Oct 30, 2004 | 12:36 AM
import6666's Avatar
GSXR
so what do you do with all the lines that hook up to the ABS unit, do you just buy brass fittings that close those lines or what?
Old Oct 30, 2004 | 05:23 AM
Nobody
You cut them out of the car. You have to get new front brake lines and a Non ABS proportioning valve
Old Oct 30, 2004 | 11:15 AM
_Chris_'s Avatar
I "Do" eBay
looks like alex needs to update his sig and avatar
Enter Signature Here
