clutch issues
Old Oct 13, 2004 | 05:27 AM
boosteddsm's Avatar
Awd the enemy of fwd
Default clutch issues
OK i just put a new clutch in my gsx and it strating to slip,, I have bleed the clutch 4 times now to make sure there is no air in it, that didnt fix the problem, i adjusted the clutch down and after diving it for a while the clutch wont fully disengage and i can barely shit it. So i adjust it out a lil bit it feels great, after driving it for a while it loses its adjustment again and will start slipping again. I just cant find a happy medium with the adjustment.. Any ideas would be great. Fly wheel was resurfaced and is in good condition,and im using a borg warner performer clutch equal to the act 2600
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old Oct 13, 2004 | 06:53 AM
nouseforaname's Avatar
16.4@84mph
The flywheel may have just been resurfaced on the contact part, make sure the step btwn the contact surface and pp mounting surface are within spec.
89 Mirage-Intake/Header/Exhaust
AIM-queerpuncher
Old Oct 13, 2004 | 07:00 AM
Ian MMF's Avatar
Omnipotence
I have always used a fidanza flywheel. The last thing you want is a stock flywheel blowing up on you, unfortunitally it seems to happen often. Nothing like having a sfi flywheel and whenever you replace your disk just replacing the replacable fidanza surface also. It's about $50 and it's almost as good as new. Plus the weight reduction from the flywheel just made it an easy decision for me. Best $250 I ever spent on the car IMO.
Old Oct 13, 2004 | 08:10 AM
joeyk's Avatar
THE MAN
Default Re: clutch issues
there is and never will be a case of air in the line causing the clutch to slip , if anything pressure wise is causing it to slip it is with the master being out of adjustment , you should try turning the adjustment screw all the way in the back it out till there is just alittle slack left in the shaft then see how it goes , other than that if everything with the clutch is fine "because you say it is all new or reworked" than it cound be the master not releasing all the way , is this problem with it slipping inconsistant or constant???
Old Oct 13, 2004 | 03:39 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
how many miles are on the clutch?
SUCH IS THE RULE OF HONOUR.
