ok i need help
i hate to sound stupid but ive tried pretty much everything
my 14b finally blew, oil was couple inches in my intercooler, slapped a new 16g on and it smokes more now then before the turbo let go. i am begging to think my valve stem seals are bad but wouldnt it of showed signs of them going bad, and not just letting go. i got a ticket for driving down the road and trying to clear the smoke out, i have had 3 sets of new plugs and ran all kinds of seafoam and shit from my work to clean the vacum lines, nothing helps
SUCH IS THE RULE OF HONOUR.
first try to test compression in your cylinders.
What color is the smoke? Do you start to overheat at all?
I'm not so sure seafoam is good stuff, nothing that I would ever put in my engine. Acutally I would never put anything in my engine other than oil.
Heavy car with a 2.5L
Yea dude that seafoam shit is a bad idea from what I have heard of it. It may be your seals, if so I have a spare set here you can have if it helps. Only problems is I'm in orlando. Do a compression check and get back to us.
the smoke is blue/gray , no overheating
ok thanks ill do compression test tommorrow and let you know
thanks, thats pretty much what i thought it was. when do you think i could pick up those seals?
how long would it take to mail, i dont know where cocoa beach is, and i dont know of i would be able to get up there
