i need help
ok my laser is idling bad like it wants to die. i need to change the fuel filter i know thats the problem. i have checked everything else and this is the last thing. now heres my problem. my bottom fuel line is rusted to my fuel filter so now what? how do i get it off with out braking the line and if i have to where can i find new fuel lines? i have been looking all over on line and can't find them. so what should i do?
try pbblaster to break the fuel line from the filter.
if it breaks, don't get a replacement fuel line, upgrade to AN lines. there is a great mitsu special on www.fuelinjectorclinic.com
1998 Eclipse GST
1998 Eclipse GST
+99,999,999,999 on PB_BLAST!!!!!!!!!!!!!!!! but to answer your question of what to do if you snap or twist the line...you can go to NAPA and they have high-pressure fuel line...you can use some inbetween the two pieces of hard line and use two worm clamps to one the end of each side (just make sure you clean up the jaggid hard lines and that you dont crush the lines with the clamps)...im pretty sure 5/16 will fit perfectly over the hard lines
Bizzare Customs
Land O' Lakes, FL
Bizzare Customs
Land O' Lakes, FL
