weird idle
Old Aug 6, 2004 | 08:14 AM
4gpusherny's Avatar
sorry for riding this post but i was thinking of removing the smaller honeycomb after reading an article in vfaq.com for better air flow , now if i do this will there be any probs id be facing after doing this ?
NYCCDSM MEMBER , GONE OUT V8
HUNTING !!
Old Aug 6, 2004 | 10:37 AM
boosteddsm's Avatar
Awd the enemy of fwd
you might experience rough idleing on cold start ups, but once the car heats up the idle should smoothin out some, and it also supposed to lean out your car a tad lil bit, because it runs so rich from the factory...
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old Aug 6, 2004 | 10:40 AM
boosteddsm's Avatar
Originally posted by ChrisMonsod
no all the honey comb is there .. ill chage the plugs tommorow but i think there fine
My car was just runnin like shit the other day bad idle and breaking up under boost, changed the wires and plugs bada bing runin good agian beside the clutch wantin to slip.. When was the last time you changed your plugs? If your runnin pretty rich youll have carbon uild up on them and replace them...
Old Aug 6, 2004 | 10:42 AM
boosteddsm's Avatar
also your tps sensor if it going out that will make your car idle like shit too.. Just another piece of info for to try and diagnose your problem..
Old Aug 6, 2004 | 08:33 PM
TIM TIM TIM's Avatar
could be worse
dont know that much about the dsm's... but could it be a vacume leak? i know un even idle is caused by that
aim:because tim said
Old Aug 6, 2004 | 08:41 PM
TBSpyder's Avatar
I'd look further into the MAS.
Old Aug 8, 2004 | 01:23 AM
  #17 (permalink)
ChrisMonsod's Avatar
Drives a cowboy corvette
Old Aug 15, 2004 | 07:17 PM
  #18 (permalink)
AnthrAxNSB's Avatar
first
Hey Chris...remember that little tutorial I gave you. All your answers are in there. Didn't I mention an intake leak Also, I have a leak tester, although mine is made to install on a 14b turbo compressor inlet, so idk if it'll fit the t25.
Old Aug 15, 2004 | 07:28 PM
  #19 (permalink)
gabe's Avatar
clever individual
idle screw
-gabe
Old Aug 16, 2004 | 06:32 AM
  #20 (permalink)
sup cory
yeha ill have to have you check it out
i do have a 14b so it should work right ..
when you have time you think you can check it out for me ?
thanks chris
