eclipse running like crap
Old Jul 20, 2004 | 01:31 PM
freakasis's Avatar
Question eclipse running like crap
i have a 1992 eclipse with the SOHC motor. the rpms at idle speed realy vary alot like from 500 to 1.5k i dont know why. it dosent matter if the ac is on or not. it just vibrates when the ac is on if the rps drop. plus there is a major power lag somewhere. i am guessing its a sensor problem but i dont know which one. any ideas?
Old Jul 20, 2004 | 01:41 PM
TBSpyder's Avatar
Does that platform use a MAS or MAF?
Old Jul 20, 2004 | 02:24 PM
freakasis's Avatar
i dont know. why?
Old Jul 20, 2004 | 03:39 PM
TBSpyder's Avatar
Could be the source of the problem.
Old Jul 20, 2004 | 04:22 PM
BoostLogik's Avatar
BoostAddict
It could be a number of things....It could be fouled spark plugs, faulty/fouled oxygen sensor, a defective or gunked-up idle speed control (ISC) motor, leaking injectors, a cracked vacuum hose, or a damaged intake manifold gasket. High idle can also be caused by a throttle cable or cruise control cables that are too tight.
Try starting out with the easiest first and work your way down to the hardest/costliest. I'd check also to see if your throttle cbale might be loose.
"Even through the darkest days, this fire burns, always"
Old Jul 20, 2004 | 06:55 PM
freakasis's Avatar
how tight should the throttle cable be? i will check the vacuum hoses again. i tried upping the regular idle from 900 to 1200 in hopes that the low idle would go up from 500 to 800 but now it has a high of 1200 and a low of 500. when the ac is on its very difficult to get it in to first gear without letting it die.
in two weeks (payday) its getting:
mounts
head gasket
intake gasget
exhaust gasket
cap&rotar
plugs&wires
valve job
and anything else i have money for
Old Jul 20, 2004 | 09:08 PM
Dunecune442's Avatar
well it is a DSM...
jfwy...
Yea check the maf... or mas, whichever you have.
possiibly throttle linkage?
Old Jul 20, 2004 | 09:10 PM
Steez's Avatar
Keep it REAL
Originally posted by Dunecune442
well it is a DSM...
jfwy...
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Old Jul 21, 2004 | 06:30 PM
freakasis's Avatar
alright i will check/change the sensor when i do the other jobs, and i guess we'll see. thanx
"Black people can't be racist" - Some black guy.
