adjusting the clutch pedal
Old Jul 11, 2004 | 12:30 PM
boosteddsm's Avatar
Awd the enemy of fwd
Default adjusting the clutch pedal
i have read that you can adjust your clutch on the 2g`s. Just wondering how i can do that, my clutch only disingages all the way to the floor. And if the floor mat gets in the way ill grind gears because the clutch is not all the disengaged.
Old Jul 11, 2004 | 01:15 PM
Rich's Avatar
Old School.
Climb underneath your dash. There is a rod near the gas pedal that threads into the master cylinder. Loosen the nut on it, and spin the rod with your hand. Spinning the rod counter clockwise should bring the clutch off the floor. Spinning the rod clockwise should move the engagement point toward the floor. Rotation is in relation to the bracket. Move it a little at a time, and go ahead and bleed your clutch if you haven't done so already, because its good to do.
You may know who we are, but we KNOW who you are.
Old Jul 12, 2004 | 10:12 AM
boosteddsm's Avatar
thanks rich for the info.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old Jul 12, 2004 | 10:44 AM
Rich's Avatar
Old School.
No prob, did you get it straightened out?
Old Jul 12, 2004 | 05:05 PM
TampaTSi's Avatar
fyi: this is a great writeup:
http://www.teamrip.com/clutch%20adjustment.html
1998 Eclipse GST
Old Jul 12, 2004 | 08:04 PM
boosteddsm's Avatar
great site very good info, thanks
