Brakes
Old Jun 30, 2004 | 07:18 PM
RkSport's Avatar
Default Brakes
I have a 96 gs auto.. I got my brake pads replaced from just brakes about 2 weeks ago and they told me my rotors were warped and need to be replaced because there wearing the pads down quikly.. Well they wanted to charge me 500 dollars and i did not have the money do i did not have it time... well now 2 weeks later i here some sqeeking.. and on my left back drivers side wheel sometimes it a very deep like rubbing/grinding sound im not sure what it is or where i should take it too. how much do you think this will cost to get fix..?
Old Jun 30, 2004 | 08:07 PM
Skillionaire's Avatar
Nobody
Replied on TBDSM, let me know
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Jul 3, 2004 | 10:43 AM
GsEclipse02's Avatar
go and get the rotors turnd or w.e. they call it for like 12 bucks and that should fix that problem
Old Jul 5, 2004 | 10:49 AM
turbobird21's Avatar
You'll See, O You'll See
even new rotors cost maybe $25-35 each. you can get front and rear brakes, rotors and labor for maybe 350.00 that includes liftime warranty on pads. PEPBOYS
Old Jul 5, 2004 | 02:19 PM
TBSpyder's Avatar
Hey man, I had the same problem. That grinding noise in one of my front brake pads and it was gouging the rotor. Definetly shop around, I took mine to Just Brakes as well and they came back and listed just about every brake component as worn or bad. Gave me a quote of around $600 for everything and I laughed at them. So then they negotiated. When all was said and done they ended up replacing both front rotors, front and rear pads, front calipers, and a 4 wheel brake alignment or something. Cost $400. I had them give me the old stuff and half of it didn't even look bad. I think I got ripped off, but I was kind of backed into a corner being this car is my only transportation and the car was barely driveable (grinding REALLY bad). If you're able to shop around, I would recommend it. I considered buying the parts myself and doing it (like someone mentioned) but I realized there's alot more to your brake system then you think, not to mention special tools you need. I think it would be smarter to have it done professionally, especially if you don't have extensive experience in the field...there's alot that could go wrong, in which case you're going to be paying for a professional to fix your mistakes and do it all over in the end anyways.
Old Jul 5, 2004 | 08:01 PM
FiReBReTHa's Avatar
Goodbye thanks 4 the fish
heya,
Theres a group buy on brakes going on and we need a couple more people to finish it up. check it out further in the forum and if you need install i charge corona and buffalo wings.
-Rick
04GSXR
96 Eagle Talon TSI AWD.
