WTB: 4g63 swap
Old Jun 21, 2004 | 11:07 PM
vertigo_16201's Avatar
Default WTB: 4g63 swap
complete swap including turbo manifold, intakemanifold, charge piping, MAF, etc etc. Trying to convert a GGSX to turbo, dont need tranny.
I would psot htis in WTB but more of the people i would need to see it would be in here
Old Jun 22, 2004 | 02:15 AM
BoostedRS's Avatar
I can freeze time
Default Re: WTB: 4g63 swap
What's a GGSX??
Olympus Evolt E-510, E-520, E-30 x 2
11-22mm f/2.8-3.5 Zuiko Digital
14-54mm f/2.8-3.5 Zuiko Digital
35-100mm f/2 Zuiko Digital
50-200mm f/2.8-3.5 ED SWD Zuiko Digital
Cybersync wireless trigger
FL-36R, FL-50R, Metz-48, and Vivitar 285HV x 3
Old Jun 22, 2004 | 03:40 AM
Ian MMF's Avatar
Omnipotence
GGSX is a Galant Gsx. All wheel drive, no turbo. It's pretty much a regular galant but awd.
Old Jun 22, 2004 | 04:27 AM
Lay Maha's Avatar
Jaded Mitsu
Default .
why don't you just swap the head with a 1g or 2g turbo? It would be cheaper than swaping a whole engine. Maybe I'm wrong
Old Jun 22, 2004 | 05:12 AM
Ian MMF's Avatar
Omnipotence
Default Re: .
The head on the ggsx is the same as a head on turbo 4g63. He wants to do a full swap so he can run real boost. Not only 6-8lbs in fear of melting a n/a piston. It's smatter to just swap the whole motor. It's all a direct boltup motor mount wise.
Vertigo - if you want some real help on the issue go check out galantvr4.org
Old Jun 22, 2004 | 05:27 AM
F4A22's Avatar
Old School
I have the stock intake,exhaust manifold,mass,piping,and alot more things.Pm me as i have a oem dsm partshouse.
Old Jun 22, 2004 | 07:34 AM
Chris LS's Avatar
just blaze...
if you can't find any here, also check http://tampabay.dsm.org as well
Quote : I'm Slow:
Less hours = less $$. Less repetitive 'ish every day = PRICELESS!
Old Jun 22, 2004 | 08:09 AM
Tom N's Avatar
Non DSM.....DSM guy
I have everything you need. Complete motor with all accesories from throttle body to exhaust manifold. Intake pipe w/ MAF and stock intercooler set up. make me a offer on it all.
Not sure if you know this but the Galant GSX has a different rear gear than the eclipse so if you ever want to change to a turbo tranny you will need to change the rear end also. I also have a stock rear from a eclipse with good axels i will sell cheap if you think you will every need it.
Tom
Old Jun 22, 2004 | 11:27 AM
The GGSX has a 5.4 FD which I like. I dont see a need to get lower gears from the T/E/L, i will send u a pm shortly
Old Jun 22, 2004 | 11:35 AM
Tom N's Avatar
Non DSM.....DSM guy
The GGSX has a 5.208 final drive and a 2.846 rear gear.
E/T/L awd manual tranny has a 4.929 FD and a 3.545 rear gear.
The thing with the GGSX rear gear is you have to use the non turbo tranny with it and its not as strong. You cant upgrade the tranny with that gear in there.
Tom
