Profec-b Boost Controller Problems...help!
Old May 21, 2004 | 05:58 PM
russellbeermann's Avatar
F*ck da rent, get the Lex
Unhappy Profec-b Boost Controller Problems...help!
I JUST GOTTA 97 GS-T AND I DON'T BELIEVE THAT THE PROFEC-B IS HOOKED UP CORRECTLY. THE BOOST GAUGE WORKS FINE, BUT I'M NOT SURE WHERE THE VACUUM TUBES SHOULD GO. I FOUND A BUNCH OF HOSES JUST HANGING AROUND. I WAS WONDERING IF SOMEONE COULD DO A WALKTHROUGH OF WHERE WHICH HOSES SHOULD CONNECT TO WHICH NIPPLES. I NEED TO HOOK UP THE PROFEC-B, T3/T04, AND A DELTAGATE WASTEGATE. THE WASTEGATE HAS TWO NIPPLES. I KNOW I SOUND LIKE AN AMATEUR, BUT THIS IS MY FIRST TURBO CAR. THANKS FOR THE HELP.
Old May 22, 2004 | 09:22 AM
Skittle's Avatar
You Can't Moderate Me.
i got the profec b spec II,it's a good ebc if ya can figure it out....goodluck...i'd say something but dont know how DSM's work...sorry bro
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
Old May 22, 2004 | 11:47 AM
slowy's Avatar
13.04@104mph
i yanked the whole bcs stuff
nipple on the comp housing connects to the IN on the profec solenoid.
nipple on the wastegate connects to the OUT of the profec solenoid
and just plug the intake nipples if u removed the vac lines
its quite simple
