Uhm... my BABY is broke...i think
I discoverd today that my radiator had a crack in it. I filled up the coolant and went to the store to get patch materials. On the way there some kid rolled up next to me...in a moded SUNFIRE hehehehe He floored and... I said what the heck... I punched it and my car...bogged... and then it kicked in..and I made quick work of him... but I was worried... I picked up the stuff I needed... on the way back my car was running LIKE SHIT! Little power... it would idle well but when I gave it more throttle.. it would bog real bad... wouldnt get out of 3K RPMs... I was like...is my engine blown... I didnt see any smoke or anyhting like that... no leaking fluids... it was running great just an hour before... whats going on... the car is cooling right now... then Ill go out to see WTF is wrong...
20G (displacement replacement)
could be a vac line leak
Originally posted by bigB
i was talkin about angela and i can handle whatever the fuck you got. call me a pussy to my face and we will see what gets wet.
cheack your plugs ,it sounded like u ran lean , i say change your plugs and did u hit the nitrous? and if its a dry zex kit then thats most likly what happen..ps i dont know any thing about your set up i just read your name
but not for long
hehehehehe SHHHHHHHHH! dont tellem.... howam I posed to make dolla dolla bills yall... Im a lil skurd.. when ish like that happens to my car... if it broke I think Id cry... Im gonna check the plugs and wires first... check for boost leaks... then... call chris again if I cant fix it.....
OK IT IS BROKE! I took out my spark plugs hoping it was something like a bad wire... water fell off of my plug... I looked inside and there was water on top of my piston. CHRIS!!!!!!! HELP!!!! MY ISH IS FUGGED UP! I am guessing it is my head gasket... and I never did one on a car before...
if your changing that it a good idea to change your belts and waterpump and some other stuff
i hope you got some money saved up. good luck
lol..we will be on our way tomorrow, hopefully someone will have a gasket local. I was going to also suggest to do the timing belt/water pump, unless that was redone when the engine went in the car?
cheack your oil and see if it looks milkie, or look in your coolent,if there is any oil, iv done 3 head gaskets on this motor ,the easy motor iv every worked on,auto zone head gaskets are $32 and some change.. good luck , one more ????? do u here any knocken,if not i wouldnt worrie to much
well... it was ticking... but it ticks because of my lifters... no knocking sounds tha tI could tell... I have a water pump, belt etc... I have ARPs on the way... as well as a gasket due here thi week.. with any luck
