overboost prob
Old Mar 5, 2004 | 05:01 PM
superhatch69's Avatar
Default overboost prob
i have a 1g awd some minor boltons and its keeps on boosting 20 psi and i switched out the actuator 2 times still doing it pls help
Old Mar 5, 2004 | 06:13 PM
Skillionaire's Avatar
Nobody
check your lines going from boost source to wastegate. You may have a leak somewhere.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Mar 5, 2004 | 07:04 PM
i did hopefully i fixed the prob i will find out sat i ran new lines and got rid a bunch of bullshit under the hood
phearable.net for all your tuning needs
Old Mar 6, 2004 | 05:26 AM
flubyux2's Avatar
Elitist Supra Asshole :)
come get our spare WG actuator. i konw for a fact this one works. it was on our old 14B that we thought was shot, but it turned out to be a boost signal line w/ a slit in it.
Old Mar 6, 2004 | 01:13 PM
DSTGST's Avatar
factory turbo charged car
make sure your boost controler is perfect. faulty boost controlers suck. good luck
TURBO IS THE ONLY WAY TO GO. IF YOU DON'T HAVE ONE GET ONE. HA HA
ALSO FRIENDS DON'T LET FRIENDS DRIVE STOCK.
Old Mar 7, 2004 | 12:51 PM
thanx flubyux2 i will do so soon as i can thanx
Old Mar 7, 2004 | 02:50 PM
SpoolinAWD's Avatar
Do you have a boost controller?
Are the vacuum lines ran like they are from the factory with the boost control solenoid still hooked?
Try taking vacuum from another source and running it directly to the wga.
Old Mar 8, 2004 | 08:30 PM
no boost controller hooked up stock
