boost
Old Mar 1, 2004 | 12:02 PM
ben's Avatar
ben
Default boost
i just recently installed my turbonetics mbc and it was running just fine. the other day i was driving and i noticed on the boost guage that it wasnt holding boost. it will peak then gradually drop off as i go higher into the rpms. i took the whole thing apart thinking there was a leak in one of the hoses and now im still left with the same problem????? any help would be great.
Old Mar 1, 2004 | 12:04 PM
Skillionaire's Avatar
Nobody
if you are on the T25, its prefectly normal
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Mar 1, 2004 | 12:28 PM
Rich's Avatar
Old School.
List more of your setup. Like skllionaire is saying, most likely your engine is using more air than your turbo can provide resulting in less boost pressure.
You may know who we are, but we KNOW who you are.
Old Mar 1, 2004 | 12:32 PM
ben's Avatar
ben
when it was working right it would have plenty of vac when i would disconnect it. now there is none. i just recently took out my walbro 255 fuel pump but i dont think that would have anything to do with it?
Old Mar 1, 2004 | 12:42 PM
Sneakin Deacon's Avatar
PSSHHH x2
ya know i had this same problem on my laser, sometimes out of the blue, there would be no vacuum in the lines with the engine running!...mike even saw this, the guage stayed at 0 and didnt move, went to boost fine, but i think it was just something to do with where it got tapped into...also i was loosing boost too on the 14B...17psi around 4800, then slowly dropped off to 13 or so by 6k
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
