Squeaky Belts?
Old Feb 23, 2004 | 06:10 AM
TBSpyder's Avatar
Arrow Squeaky Belts?
Well, along with my UDP I put on new belts as well (alternator & water pump). Seemed to be fine for awhile,but now they are squeaking alot when I first start the car and drive it. It usually stops once the car has warmed up though (3-4 minutes of driving). And it doesn't do it at idle...only while accelerating. Someone said the tensioners might be bad? I was thinking they're too tight? Maybe too loose? They seem nice and snug to me, but I'm no mechanic. Any opinions welcome...
Old Feb 23, 2004 | 07:45 AM
_Chris_'s Avatar
I "Do" eBay
usually means they're loose, my 98 rs used to have that problem all the time when you accelerate everything pulley spins faster... and they're spinning in the belt
Enter Signature Here
Old Feb 23, 2004 | 09:32 AM
psifactor's Avatar
Hello
mine did the same thing when the alternator/waterpump belt was not on there tight enough.
Heavy car with a 2.5L
Old Feb 24, 2004 | 06:29 PM
7273kgt's Avatar
I HAD THA EXACT SAME PROBLEM.....A THING THAT WORKS IS JUST GET LIKE ONE OF THOSE LONG STICK CANDLES AND RUB IT ON THA BELT WHILE THA CAR IS RUNNIN...I SWEAR IT TAKES AWAY THA SKEAWKING.....TRY IT...NO NEED TO GET N E THING OR TIGHTEN SHIT
Old Feb 24, 2004 | 06:39 PM
Sneakin Deacon's Avatar
PSSHHH x2
...cut the caps...and give an explanation as to what your describing. how does it stop the squeakin?
if the tensioner is bad, he should get a new one...could be the pulley of an accessory itself also. run the car and listen to where its at
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Feb 24, 2004 | 07:02 PM
AnthrAxNSB's Avatar
first
this is usually the case with any new part installed. if it didn't do it before, then it's either the new part or the installation. odds are a pulley or manual tensioner didn't just go bad at the point of install of the new belts. check the deflection and tighten or loosen if necessary.
Old Feb 24, 2004 | 09:48 PM
Zirc's Avatar
Tampabay DSM
pry-bar and tighten
92 Laser AWD
Old Mar 1, 2004 | 07:48 PM
str33tracer_18's Avatar
tighten up a little dont over tighten or your belts will break.i finally got my belt breaking problem fixed.(knock on wood)
