6 bolt into 2g
basically two questions... what all do you need and who will do it... i know the cam angle sensor and thats about all i know... is there a bunch of ecu work that has to be done? what about the heads? will a 2h head work w/ a little bit of timing adjustments... any help at all would be appreciated...
thanks,
chris
thanks,
chris
almost dumped 07 SI
almost dumped 07 SI
not a lot of ecu work. actually, you use all the 2g computer...and just splice the CAS into the wiring harness. i thought the wiring was the easy part.
http://www.magnusmotorsports.com/1g2g.asp
that site has the most details on the current swap steps. leaves a lot to the imagination, but sign up for the 1gina2g yahoo email group, and they'll fill in the details.
1998 Eclipse GST
1998 Eclipse GST
